查看: 29974|回复: 19
第一贴来点建伍高级双段车台。TM D700。让你流口水
1117
商家认证
发表于 2012-12-4 22:13 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
成色不错以图为准..差转.频普.全频接收.GPS功能(选件).哑音.数子哑音.SSTV功能.此机功能太多.同时可以工作.UU VV  UV VU 接收.远程无线控制.附件全套全在.V段50W U段35W.工作频.136-173MHZ 收发。 400-470MHZ 接收全段.接收是。118-173MHZ 300-399MHZ 400-520MHZ 800-1299MHZ。转让价。3999
请看参数/
Modifications for the Kenwood TM-D700
KENWOOD TM-D700A Extended TX MOD (easy 3 steps)
TM-D700 CAP/MARS
Attention: If you looking for the TM-D700A software or any more information about this radio
                        click here to download.
Just received my new rig, neither the supplier nor Kenwood had the mods available to date.
Remove the bottom cover, 5 screws (not the speaker side).
Locate and remove "W601" (chip resistor) and "W602" (green wire). They are located within 2 inches
of the optional VS-3 voice synthesizer board.
Reassemble radio and after power-up, press the reset switch on the front of radio.
Here is your new TRANSMIT range
136.000 - 174.995
400.000 - 469.995
This is the RECEIVE range (mode selected).
118.000 -  135.995
136.000 -  199.995
200.000 -  299.995
300.000 -  399.995
400.000 -  523.995
800.000 -  823.990
849.000 -  869.990
894.000 -  913.990
934.000 - 1299.990
If anyone finds other mods please drop me a line.
TM-D700 CAP/MARS
To modify the transmitter to cover 142 - 151.995 Mhz and 420-449.995 Mhz, perform the following steps:
MOST IMPORTANT - this mod will do a reset on your radio and erase ALL of your settings
(memory, APRS, menus, etc.). Use the computer program to pull all of the settings out BEFORE you go
any further. Or if no computer, a very large tablet. This radio has many programmable features.
Turn off the radio and disconnect the power
Remove the five screws from bottom cover (not the side with the speaker).
Remove the bottom cover. It may take a little prying with a small screwdriver.
REMEMBER if you haven';t saved your settings, all will be lost if you proceed beyond this point.
Cut ONLY the famous Kenwood green wire, located near the voice synthesizer board connector.
The green wire ties two PC board lands together and is about 1/2" long. Make sure the ends can';t short
against anything.
Reinstall the bottom cover.
Reapply power and turn the radio on (it will automatically reset).
Use the computer program to reinstall all of your operating parameters. I found that the load ALL function did
not seem to do everything. Try the load MEMORY and MENU selections too. Or prepare to spend a whole
bunch of time re-entering all of your parameters that you wrote down in step 1
江苏省盐城市射阳县城市管理局。茆祥。
手机13961968833  15301418333
呼号。BD4XVG
支付宝 13961968833@163.com   茆华祥
淘宝BD4XVG通讯http://shop66784041.taobao.com/shop/view_shop-44547e31bda2781df597a43a85ed0290.htm?spm=a1z09.5.0.45.xVaDIw
农行 622848.198803.6399.777.茆华祥
78
发表于 2012-12-7 22:49 | 只看该作者
55
3#
发表于 2012-12-7 23:57 | 只看该作者
老朋友好东西真不少啊
32
4#
发表于 2012-12-7 23:59 | 只看该作者
朋友好东西真不少啊
1259
5#
发表于 2012-12-8 16:06 | 只看该作者
别看价格贵,物有所值。顶。
1117
商家认证
 楼主| 发表于 2012-12-8 18:05 | 只看该作者
浮生晓月 发表于 2012-12-8 16:06
别看价格贵,物有所值。顶。
谢谢。。各位。。帮顶
江苏省盐城市射阳县城市管理局。茆祥。
呼号。BD4XVG
616
发表于 2012-12-10 23:34 | 只看该作者
都是好东西啊
天涯咫尺,通联无限。
7001
管理员
8#
发表于 2012-12-11 03:21 | 只看该作者
流口水的机器
山东济南诚迎通讯技术经营部
呼号:BG4JUD 姓名:刘庆诚 QQ: 553056154 电话:手机和微信号15966320101 通讯地址:山东济南天桥区明湖西路茂新街-区2-2-703  农行卡号;622848 0251 22188 9610农行开户行:济南天桥区支行。 工行卡号:6222 0216 0200 1723 586 工行开户行:济南历下区支行 。建行:6222802340671005910  建行开
1117
商家认证
 楼主| 发表于 2012-12-11 07:55 | 只看该作者
bg4jud 发表于 2012-12-11 03:21
流口水的机器
谢谢老朋友
江苏省盐城市射阳县城市管理局。茆祥。
呼号。BD4XVG
104
10#
发表于 2012-12-11 10:18 | 只看该作者
无限垫,无线电。
