查看: 26322|回复: 22
中外收音机历史回顾展览室--部分产品介绍
5012
发表于 2014-6-23 23:34 | 只看该作者 |只看大图 回帖奖励 |倒序浏览 |阅读模式
索尼 SONY
    Sony-ICF5500
    Sony-ICF5800
    Sony-ICF6800
Sony-ICF-SW7600G
The Sony ICF-SW7600G is a         compact, microprocessor-controlled, frequency synthesized general coverage         portable receiver. Direct access tuning is provided along with a multifunction         LCD digital readout for unsurpassed convenience and accuracy (1 kHz step         tuning on longwave, medium wave and shortwave). Just press the numbered         keys to match the frequency you want to hear. Manual and automatic scan         tuning are also provided. Twenty-two memories are provided for your favorite         stations. The ICF-SW7600G tunes from 150 to 29995 kHz for solid coverage         of longwave, medium wave and shortwave. Smooth Single Sideband (SSB) and         Morse code reception is now provided through a switch with separate LSB         and USB positions plus fine tuning thumb-wheel. A special Synchronous         Detector circuit reduces fading and annoying "beat" frequency         interference from adjacent stations as well as distortion due to fading         shortwave reception. FM stereo (76 - 108 MHz) is provided to the mini         stereo headphone jack. A record output jack is included for taping off         the air. Advanced features include: dial light, LED tune indicator, tilt         stand, keypad lock, 24 hour digital quartz clock with dual timer, Local-DX         sensitivity switch, 9/10 kHz MW tuning switch, tone switch and external         antenna jack.
Supplied accessories include: vinyl           case, AN-61 wind-up antenna and Sony Wave Handbook. Only 7.5 x 4.75           x 1.25 inches 22 oz. (190x120x32 mm 624 g). (3 Lbs. ship weight). One           year limited warranty. This radio requires 6 VDC or four AA cells (not           supplied). This radio may also be operated from the optional Sony AC-E60A           or AC-E60HG wall adapters.
ICF-7600GR
Sony-ICF SW77
The Sony ICF-SW77         offers sophistication not previously seen in portable or table top receivers.         On the performance side of the equation, this radio offers several useful         circuits. A built-in programmable RF tuning unit allows the set to track         a signal from the time the antenna first picks it up, while cutting out         other signals. This reduces interference. The SW77 incorporates a band         pass filter that splits each band into five smaller bands, thus virtually         eliminating interference from outside the band. Fifty Hertz tuning resolution         permits precise signal tuning for maximum clarity (LCD resolution is 100         Hz). The advanced synchronous detection circuit effectively addresses         the two biggest problems on shortwave: fading and interference from adjacent         stations.          The SW77 is also rich in features. Station Name           Tuning is now a reality. 162 memories are available to store your favorite           stations including: frequency, name (to six characters) and program           times. Sony has preset 94 of these memory channels with the world's           most popular SW stations. (You can over-write these factory-set memories).           You select the station name and the radio will provide the best frequency           based on the current time! The SW77 also includes all the expected features:           excellent AM & FM bands, keypad entry, light, bass, treble, LSB/USB,           ext. antenna jack, dial lock, S-Meter, sensitivity switch (Local/Normal/DX),           manual tuning knob, frequency scanning, dual clocks, five-event timer,           etc. There is a 3.5mm Line Output for a mono tape recorder plus a Tape           Remote jack that can be used for tape recorder activation. (For stereo           tape recording you must use the stereo earphone jack).
        Inside the battery compartment there is a switch           to select 9 or 10 kHz medium wave steps. Despite its advanced and many           features, the SW77 provides a friendly "interface" between           the listener and radio.
        Requires four C cells (not supplied). Includes           adapter for 120 VAC operation, stereo earphones, carrying belt and AN-71           wind-up antenna. With: Owner's Manual, How To Catch The Wave and Wave           Handbook.
        Size: 11 x 7 x 2 inches, 3.25 Lbs (279x177x51mm,           1.56 kg). (5? Lbs. ship).
        Optional DCC-E160L vehicle cigarette lighter           adapter is also available.
    Sony TR-72
收藏收藏1 分享分享
CQCQCQ中国业余无线电,有您更精彩!
449
5012
2#
 楼主| 发表于 2014-6-23 23:35 | 只看该作者
松下 PANASONIC
    National-RF2200
5012
3#
 楼主| 发表于 2014-6-23 23:38 | 只看该作者
根德 GRUNDIG
  Grundig Satellit 400
  Grundig Satellit 500
  Grundig Satellit 650
  Grundig Satellit 700
Grundig Satellit-800
Grundig YB-300PE
Grundig YB-400
  Grundig YB-500
5012
4#
 楼主| 发表于 2014-6-23 23:40 | 只看该作者
日立 HITACHI
    HITACHI KH-2200
    Hitachi KH-WS1 WORLDSPACE RECEIVER
5012
5#
菲利谱 PHILIPS
    PHILIPS D2999
5012
6#
 楼主| 发表于 2014-6-23 23:41 | 只看该作者
    Yaesu FRG-7700
5012
7#
 楼主| 发表于 2014-6-23 23:42 | 只看该作者
Realistic
  Realistic DX-302
    Realistic AX-190
5012
8#
 楼主| 发表于 2014-6-23 23:43 | 只看该作者
牡丹 MUDAN
      作者:chnepal
      这就是牡丹2241型22晶体管全波段一级收音机
      这台由北京无线电厂七十年代生产的一级台式晶体管全波段收音机,曾经作为国礼赠予来华访问的外国国家元首,这可不是我吹的,不信你去问问蓝天白云!国内收音机生产厂家及其生产过的收音机种类可谓多矣,能享此殊荣者,舍我其谁?
      牡丹2241全机共使用22只晶体管和10只二极管,共12个波段,包括了全部调幅广播波段和调频波段。短波中的8个波段设有频率展宽装置,以改善短波收听效果。
      频率划分:
        调频 88-108MHz
        短波1 1.6-5.0 MHz
        短波2 5.0-7.1 MHz(展宽后为5.93-6.23 MHz,49米)
        短波3 6.1-8.2 MHz(展宽后为7.07-7.35 MHz,41米)
        短波4 8.2-11 MHz(展宽后为9.45-9.80 MHz,31米)
        短波5 10.1-13.5 MHz(展宽后为11.65-12.05 MHz,25米)
        短波6 13-17.4 MHz(展宽后为15.05-15.55 MHz,19米)
        短波7 15.2-20.1 MHz(展宽后为17.55-18.05 MHz,16米)
        短波8 18.2-24.2 MHz(展宽后为21.25-22.05 MHz,13米)
        短波9 21.5-30 MHz(展宽后为25.45-26.75 MHz,11米)
        中波 535-1605K Hz
        长波 150-400K Hz
      主要规格:
        输出功率:不失真功率 4W 最大5W
        中频:AM 465KHz, FM10.7MHz,
        电源:18V 随机配有ZL-1型交流供电转换装置 也可使用12节1号电池供电
        体积:684×320×236mm
        重量:18Kg
      本机采用了陶瓷滤波器,并有带宽控制装置。低频放大器采用无变压器电路,音调补偿部分除可以分别使用独立的高、低音控制钮调节外,还设有语言、演唱、低音、管弦乐等五种固定音调控制器,以满足收听不同节目之需要。
      在结构上,调频与调幅接收电路的高、中频部分完全独立,低放部分共用。短波2-9的采用鼓形波段开关,八个波段共使用了24块回路组件,全部安装在鼓形波段开关内。鼓形波段开关结构远比一般收音机使用的插刀式波段开关复杂,但各波段电路互不影响。调谐部分有飞轮装置以增加惯性,手感极佳。调频与调幅虽共用一个调谐钮,但调谐轴上有与波开关连动的离合装置,切换到调幅时,调幅部分的可变电容器及调谐指针运动,调频部分不工作。反之亦然。两根磁性天线安装在可转动的铝制支架上,可通过旋钮转动磁性天线,以实现最佳收听效果,磁性天线支架上装有线轮,可以带动指针在面板上显示出天线转动的位置。
      调谐指示度盘宽大而清晰,调频、长波、中波及短波1的频率均可在面板上直接读出,而短波2-9则共享一个窗口,其频率和波长由度盘玻璃后面的另一个与波段开关连动的滚动度盘显示。面板上还设有调谐指示电表,上盖掀开时可以看到世界时区表,左侧面有耳机插口,右侧面有长达1,5米的拉杆天线。机背后有拾音器、录音、外接电源和外接扬声器插口。机壳内共装有3只扬声器,正面1只,左、右两侧各有1只,音质颇为不俗。木制机壳,侧板有金属加强骨架。正面及背板标有"牡丹22管全波段晶体管收音机"和"中华人民共和国制造"字样,未标北京无线电厂厂名,正面左上方的金属铭牌上有郭沫若题写的"牡丹"         商标。
      牡丹2241是北京无线电厂牡丹系列晶体管台式机的经典作品,无论在电路设计、材料选择以及外型方面都是追求质量而不惜工本。虽然经历了二十多年的风风雨雨,它仍然显得雍容华贵,气派非凡。牡丹2241面世时,多为专业单位使用,因而产量有限。此后,台式晶体管收音机逐渐走向衰落。一代名花牡丹也逐渐失去了光彩。
5012
9#
 楼主| 发表于 2014-6-23 23:47 | 只看该作者
Tecsun/德生 PL-660全波段数字调谐立体声钟控充电德生收音机
TECSUN PL-660全波段数字调谐收音机全球同步上市!(2010-11月12日
PL-660是德生精心制作的一款便携式全波段数字调谐收音机精品。该机的调幅接收运用了同步检波、二次变频技术,调频和航空波段高频头采用五连调谐技术,极大地提高了整机接收的灵敏度、选择性、抗镜像及抗邻频干扰能力;PL-660也是德生首次设置航空波段的便携收音机。相信这款产品能满足您收听全球广播的绝大部分需求。
          可选颜色:黑色、银色
以下是在各地测试PL-660过程中的部分照片
收音机论坛网友【小马哥】提供
收音机论坛网友【wxdahz】提供
收音机网友【zjian】的照片
243
发表于 2014-11-1 21:38 | 只看该作者
珍惜现在所拥有的一切,明天和意外不一定那个会先到来
