查看: 20585|回复: 7
发一组射频功放图纸,请ham参考
发表于 2014-5-23 08:28 | 显示全部楼层 |阅读模式
VHF-UHF_Broadband_100W_Class-AB_PA.gif 1.2GHz_10W_2nd_Harm_Resonat_PA.gif 1.3GHz_0.5W_PA_DC1OP.gif 1.3GHz_1W_PA_IW2BC.gif 1.3GHz_10W_Linear_PA_DJ1EE.gif 1.3GHz_30W_PA_F4CIB.gif 1.6-30MHz_300W_PA_BLF177.gif 1.6MHz_30MHz_20W_MRF475_PA.gif 1.8MHz-30MHz_10W_MOSFET_PA.gif 1.8MHz-30MHz_10W_IRF510_PA.gif 1.8MHz-18MHz_5W_PA.gif 1.8-30MHz_250W_IRF820_PA_DK6AE.gif 1.8MHz-30MHz_30W_MOSFET_PA_DL2EWN.gif 1.8MHz-54MHz_6W_PA_DL2EWN.gif 1.8MHz-54MHz_400W_MOSFET_PA_OE2KHM.gif 1.78GHz_10W_LDMOS_PA.gif 1.8MHz-to-52MHz_50W_PD55035_PA_DL2EWN.gif 1.8MHz-to-10.1MHz_5W_MOSFET_PA.gif 1MHz-60MHz_23dBm_Driver_DK4KU.gif 1MHz-30MHz_150W_Linear_PA.gif 1MHz-30MHz_4W_Linear_PA_DJ7VY.gif 1GHz_Inverse-Class-F_PA.gif 1MHz-to-30MHz_5W_PA.gif 2.3GHz_1.5W_PA_F1JGP.gif 2.3GHz_4W_PA_F5EFD.gif 2.3GHz_10W_PA_F1JGP.gif 2.3GHz_90W_PA_RF3933.gif 2.4GHz_0.5W_GaAs_PA.gif 2.4GHz_1W_Linear_PA_DC3QS.gif 2.4GHz_2W_PA_DG0OPK.gif 2.4GHz_PA_KK7B.gif 2m_100W_Linear_PA_K3HPA.gif 2m_100W_Linear_PA_Zetagi_B300P.gif 3.4GHz_3W_PA_DB6NT.gif 3-30MHz_2W_QRP_PA.gif 2MHz-50MHz_1kW_MOSFET_PAs.gif 2m_100W_Linear_PA_Zetagi-LA1080.gif 3.4GHz_7W_PA_DB6NT.gif 3MHz-30MHz_300W_MRF454_Linear_PA.gif 3MHz-30MHz_600W_MRF150_Linear_PA.gif 5.5GHz_2.5W_MESFET_PA.gif 5.7GHz_0.5W_PA_F1HPR.gif 7MHz_10W_Impedance_Transformers_PA_.gif 7MHz_30W_HEXFET_PA.gif 10GHz_1W_PA_F1JGP.gif 7MHz_200W_Class-E-F_MOSFET_PA_KN6EK.gif 7MHz_60W_Class-B_MOSFET_PA_W1FB.gif 10GHz_4W_PA_DB6NT.gif 10GHz_200mW_PA_DB6NT.gif 10m_10W_SSB_PA_NZ5G.gif 10W-200W_Class_E-F_PA.gif 10W_HF_PA_MOSFET_LU8EHA.gif 14MHz-21MHz_5W_HEXFET_PA.gif 14MHz_100W_2SK413_PA_RSGB.gif 24GHz_200mW_PA_DB6NT.gif 24GHz_80mW_F1GHB.gif 20W_Linear_PA_for_14MHz.gif 14MHz_100W_HEXFET_Class-E_PA.gif 27MHz_1kW_Low_Cost_MOSFET_PA.gif 27MHz_4W_PA.gif 27MHz_400W_MOSFET_PA.gif 27MHz_500W_Class-E_MOSFET_PA.gif 28MHz_15W_PA.gif 28MHz_80W_SSB_PA_BLF246.gif 28MHz_100W_Liinear_PA.gif 30MHz-150MHz_30W_MOS_PA.gif 30MHz_100W_MOSFET_PA.gif 30MHz_300W_MOSFET_PA.gif 40m_5W_MOSFET_PA_WB8VGE.gif 40m_200W_CW_PA_W6EI.gif 40m_75W_CW_PA_W6EI.gif 40m_20m_25W_PA_W7ZOI.gif 40m_10W_PA_PY2MG.gif 40m_QSK_40W_PA_N5HNN.gif 40W_88-108MHz_PA.gif 40W_HF_PA_MOSFET_WA2EBY.gif 50MHz_3W_PA.gif 50MHz_35W_PA_DJ9FG.gif 50MHZ_16W_MOSFET_PA.gif 50MHz_16W_IRF610_PA.gif 50MHz_40W_MOSFET_PA_DJ9FG.gif 50MHz_150W_PA_BLX15.gif 50MHz_300W_Linear_MOSFET_PA.gif 50MHz_360W_2xBLX15.gif 70MHz_15W_PA_YO2LGX.gif 70MHz_150W_BLF147_PA_YU1AW.gif 80m-30m_400W_MOSFET_PA_W5JGV.gif 75W_PA_144MHz_preamp.gif 70MHz_160W_PA_GI0GDP.gif 80m_30W_IRF511.gif 88-108MHz_300W_MOSFET_PA.gif 88-108MHz_15W_MOSFET_PA.gif 88-108MHz_1W_FM_PA.gif 80W_3-30MHz_Power_Amplifier.gif 100MHz-450MHz_250W_PA.gif 100W_Broadband_PA.gif 108MHz_175W_PA.gif 135MHz_175MHz_7W_PA.gif 125W_144MHz_Power_Amplifier.gif 120MHz-180MHz_Class-E_PA.gif 110W_PA_144MHz.gif 135MHz_175MHz_15W_PA.gif 136kHz_200W_Envelope_Modulated_PA_M0BMU.gif 136kHz_250W_PA_G0MRF.gif 144MHz_25W_FM_PA.gif 144MHz_20mW-9W_PA_WA7KRE.gif 144MHz_13W_PA_W1OOP.gif 140-152MHz_90W_PA_KL144.gif 144MHz_30W_PA_HL-37Vsx.gif 144MHz_50W_BLY90_Linear_PA.gif 144MHz_55W_Class-E_PA.gif 144MHz_100W_2xBLY94.gif 144MHz_150W_SSB_PA_MRF247.gif 144MHz_150W_PA_LNA_SRF3417.gif 144MHz_140W_BM170_PA.gif 144MHz_100W_Linear_PA.gif 144MHz_160W_PA.gif 144MHz_400W_D1030UK_PA_DJ1EE.gif 144MHz_Push_Pull_PA_YU1AW.gif 175MHz_25W_PA_WA7KRE.gif 160m_80m_7W_Push-Pull_PA_W7ZOI.gif 150W_PA_28MHz.gif 200W_DVB_PA_and_Bias_BLF578.gif 225MHz-450MHz_10W_PA.gif 225MHz_400MHz_20W_LDMOS_PA.gif 300MHz_2.5W_Complementary_PA_WA7KRE.gif 432MHz_40W_DMOS_Push-Pull_PA.gif 432MHz_15W_PA_DJ1EE.gif 432MHz_12W_PA_RFM12U7X.gif 400MHz_520MHz_8W_PA.gif 432MHz_125W_DMOS_Push-Pull_PA.gif 448MHz_5W_PA_WA1HVG.gif 480MHz-520MHz_Class-E_PA.gif 500kHz_500W_Class-E_IRFP452_PA_G4JNT.gif 1296MHz_1W_Linear_PA_DC0DA.gif 500MHz_Class-F_Power_Amplifier.gif 500MHz_15W_DMOSFET_PA.gif 1296MHz_50W_PA_DJ1EE.gif 1296MHz_50W_UPF1060_PA_DJ1EE.gif 1450-1550MHz_45W_LDMOS_PA.gif Broadcast_FM_80W_PA.gif AM_70W_BUZ71_PA.gif 2304MHz_2.5W_PA_WA3JUF.gif Equivalent_Circuits_Class-E_PA.gif HF_6W_PA_W7ZOI.gif HF_10W_PA_KD1JV.gif HF_10W_PA_DL6GL.gif HF_10W_MRF475_PA_W1FB.gif HF_15W_Linear_PA_W7ZOI.gif HF_15W_MOSFET_PA_F5VOA.gif HF_25W_PA_IRF830_VU3VJY.gif HF_25W_PA_IRF840_VU3NSH.gif HF_50W_IRF-520_PA_NM0S.gif HF_50W_Gain-13dB_PA_WA2EUJ.gif HF_30W_FET_Push-Pull_PA_AA3X.gif HF_30W_Class-D_Linear_PA_OH2GF.gif HF_50W_MOS_PA_W6JL.gif HF_50W_PA_IRF840_VU3NSH.gif HF_100W_Cheap_MOSFET_PA_G0MRF.gif HF_100W_IRF520_PA.gif HF_180W_PA.gif HF_200W_MOSFET_PA_MRF151G.gif HF_250W_LDMOS_PA.gif HF_Low-Medium_Power_PAs.gif HF_600W_MOSFET_PA_K0GKD.gif HF_300W_VRF151_MOSFET_PA.gif HF_VMOSFET_PA_DK7ZB.gif MW_20W_AM_PA_DK1KQ.gif PA_2m_10w-in_100W-out.gif UHF_25W_PA.gif PA_70cm_10w-in_50W-out.gif PA_2m_10w-in_180W-out.gif VHF_1-BJT_PAs_WA7KRE.gif VHF_30W_PA.gif VHF_50W_FM_PA.gif VHF_150W_MOSFET_PA.gif VHF_80W_FM_PA.gif VHF_70W_PA_RD70HVF1.gif VHF_300W_DMOS_Push-Pull_PA.gif VHF_300W_MRF151G_PA.gif VHF_900W_PA_ARF476L.gif VHF_Class-E_PA.gif HF_600W_MOSFET_PA.gif 3.4GHz_0.5W_PA_DC8NR.gif 14MHz_25W_MOSFET_PA_F6BCU.gif 10MHz-to-90MHz_1kW_MOSFET_PA.gif 10GHz_1W_PA_DL1RQ.gif 3MHz-30MHz_50W_PA_WA2EBY.gif 144MHz_50W_PA_M0UKD.gif 144MHz_50W_Parallel-BJT_PA.gif 440MHz_60W_PA_W2GEF.gif 200W_PA_144MHz.gif 144MHz_300W_PA_MRF141G_ON4KHG.gif 144MHz_100W_2N5591_PA_I1RK.gif HF_15W_PA_MRF449_W7ZOI.gif HF_150W_MOS-IRF510_PA_UA1ZH.gif
176
发表于 2014-5-23 15:44 | 显示全部楼层
收藏学习
aaaa
发表于 2014-5-24 00:25 | 显示全部楼层
我~滴~妈~耶
发表于 2014-5-24 15:54 | 显示全部楼层
这么多,顶一下,就是有些图看不清。
发表于 2014-7-7 20:55 | 显示全部楼层
这个必须顶。
发表于 2014-7-8 08:23 | 显示全部楼层
这个必须顶。
发表于 2014-7-8 22:53 | 显示全部楼层
哇,这个强啊。可是都没看懂。。。。
发表于 2014-7-12 19:30 | 显示全部楼层
这么好的东东,必须占个位
GMT+8, 2025-6-18 10:34
