查看: 1540|回复: 0
Industrial wifi6 Wireless AP/DR AP6018 S AIPQ6010 2T2R supporting QCN9074 wif...
发表于 2022-12-5 13:49 | 显示全部楼层 |阅读模式
DR-AP-6018-S-A
QCN9074 WiFi Card IPQ6010,802.11ax,2x2 2.4G&5G,
Support OpenWRT
Description
DR-AP6018-S-A is a 2x2 2.4G&5G high power Radio AP Router which including 1x  DR6018-S (IPQ6010) Board;2 x 2.4G&5G dipole Antennas; 1 x PSU(DC power or PoE);
1 x Enclosure.
Dipole antenna
■  2 x 2.4G&5G Antenna
■  5dBi 2.4GHz/5Ghz
■ SMA Plug interface
■ Plastic rod of black
■ RoHS compliance
Enclosure
■  Dimension: 133x 128 x 44 mm
■  Aluminum alloy material
■ Two Version:
DR-AP6018-S-AB (color black)
DR-AP6018-S-AO (color orange)
■  Support Wally DR6018-S
    Absolute Maximum Rating
    Parameter
    Rating
    Unit
    Supply Voltage
    24V~48V(DC Jack)
    V
    Operating Temperature Range
    -40 to +70
    ºC
    Storage Temperature Range
    -45 to +105
    ºC
    Operating Humidity Range
    5 to +95 (non-condensing)
    Hardware Specifications
    Symbol
    Parameter
    CPU
    Qualcomm-Atheros IPQ6010
    CPU Frequency
    Quad-core ARM 64 bit A53 @1.8 GHz processor
    System Memory
    1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
    Ethernet Port
    1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
    NGFF Slot
    M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
    SD Card Slot
    1x SD Card Slot(Option)
    USB /header
    1x USB 3.0 Port(Option)
    POE
    24V~48V passive POE/Active POE(Suport 802.3bt)
    DC Jack
    24V~48V power supply
    LED header
    2.0 pitch pin header
    Serial Port
    1x Serial Port 4 Pin Connector
    Wireless
    On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
    On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
    4 x MMCX Connectors
    Nor Flash
    8MB
    Nand Flash
    256MB
    DDR
    256MB~512MB
    Dimension
    133mm x 128mm x 44mm
    Boot Config Switch
    Boot_Config Switch1(S7)
    Boot_Config
    Boot up InterfaceSelect
    S7A
    S7B
    S7C
    SPI NOR. (Default)
    eMMC
    QPIC, Parallel NAND
    USB3.0
    SPI-NOR-GPT
    S7D
    Boot from code ram.(Default)
    Boot from ROM
    Boot_Config Switch2(S9)
    Boot_Config
    No auth.(Default)
    Auth is required
    We'll start with a quick review of how Wi-Fi has changed over the years.
    In fact, the earliest generation of 802.11 standard can be traced back to 1997, when the wireless speed is very low, only 2Mbps, it is an original standard of the first generation .
    With the introduction of 802.11b in 1999, the physical layer speed was increased to 11Mbps and there were very few commercial applications. At that time, Wi-Fi was still far away from people's lives
    In 2003, the third generation of the standard, 802.11a/ g. Laptop began to configure wireless network card and home wireless router appeared in large quantity .  Wi-fi comes into ordinary family.
    Skype/EMAIL/Teams:sales@wallystech.com
Skype/EMAIL:sales@wallystech.com
GMT+8, 2025-7-2 11:33
