查看: 1637|回复: 1
wallys/802.11ax wifi 6 QCN9074 IPQ6010 IPQ6018 support open WRT 2X2 2.4G&5G
发表于 2022-10-27 15:35 | 显示全部楼层 |阅读模式
https://www.wallystech.com/Routerboard/DR6018-S-V02-wifi6-Qualcomm-IPQ6010-2T2R-2-GE-port-supporting-QCN9074-wifi-card-802.11AX-MU-MIMO-OFDMA.html
DR6018-S V02 IPQ6010/IPQ6018/IPQ6000
Quad-core ARM 64bit A53 @1.8GHz Processor
1GB DDRL3L System Memory
8MB NOR Flash, 256MB NAND Flash
Supports Dynamic Frequency Selection (DFS)
2x2 On-board 2.4GHz radio, up to 573Mbps physical Data Rate
2x2 On-board 5GHz radio, up to 1201Mbps physical Data Rate
Absolute Maximum Rating
Parameter
Rating
Unit
Supply Voltage
24V~48V(DC Jack)
V
Operating Temperature Range
-40 to +70
ºC
Storage Temperature Range
-45 to +105
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm-AtherosIPQ6010
CPU Frequency
Quad-core ARM 64 bit A53 @1.8 GHz processor
System Memory
1GB (2x 512MB) DDR3L 16-bit interface with 32-bit memory bus design
Ethernet Port
1 x 1Gbps Ethernet Ports & POE 1x 1Gbps Ethernet Ports
NGFF Slot
M.2 (NGFF) “E Key” Socket with MiniPCIe 3.0(For WiFi Module)
SD Card Slot
1x SD Card Slot(Option)
USB /header
1x USB 3.0 Port(Option)
POE
24V~48V passive POE/Active POE(Suport 802.3bt)
DC Jack
24V~48V power supply
LED header
2.0 pitch pin header
Serial Port
1x Serial Port 4 Pin Connector
Wireless
On-board 2x2 2.4GHz MU-MIMO OFDMA 802.11b/g/n/ax, max 23dBm per chain
On-board 2x2 5GHz MU-MIMO OFDMA 802.11a/n/ac/ax, max 20dBm per chain
4 x MMCX Connectors
Nor Flash
8MB
Nand Flash
256MB
DDR
256MB~512MB
Dimension
125mm x 105mm x 20mm
Radio TX Specifications(5180MHz-5825MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
5Ghz 802.11ax HE20
MCS0
20dBm
23dbm
±2dB
MCS1
20dBm
23dBm
±2dB
MCS2
20dBm
23dBm
±2dB
MCS3
20dBm
23dBm
±2dB
MCS4
19dBm
22dBm
±2dB
MCS5
18dBm
21dBm
±2dB
MCS6
17dBm
20dBm
±2dB
MCS7
16dBm
19dBm
±2dB
MCS8
15dBm
18dBm
±2dB
MCS9
14dBm
17dBm
±2dB
MCS10
13dBm
16dBm
±2dB
MCS11
13dBm
16dbm
±2dB
5Ghz 802.11ax HE400
MCS0
20dBm
23dbm
±2dB
MCS1
20dBm
23dBm
±2dB
MCS2
20dBm
23dBm
±2dB
MCS3
20dBm
23dBm
±2dB
MCS4
19dBm
22dBm
±2dB
MCS5
18dBm
21dBm
±2dB
MCS6
17dBm
20dBm
±2dB
MCS7
16dBm
19dBm
±2dB
MCS8
15dBm
18dBm
±2dB
MCS9
14dBm
17dBm
±2dB
MCS10
13dBm
16dBm
±2dB
MCS11
13dBm
16dbm
±2dB
5Ghz 802.11ax HE80
MCS0
20dBm
23dbm
±2dB
MCS1
20dBm
23dBm
±2dB
MCS2
20dBm
23dBm
±2dB
MCS3
20dBm
23dBm
±2dB
MCS4
19dBm
22dBm
±2dB
MCS5
18dBm
21dBm
±2dB
MCS6
17dBm
20dBm
±2dB
MCS7
16dBm
19dBm
±2dB
MCS8
15dBm
18dBm
±2dB
MCS9
14dBm
17dBm
±2dB
MCS10
13dBm
16dBm
±2dB
MCS11
13dBm
16dbm
±2dB
Radio TX Specifications(2412MHz-2482MHz)
Operating Mode
Data Rate
Power
Tolerance
1 Chain
2 Chains
2.4Ghz 802.11ax HE20
MCS0
23dbm
26dbm
±2dB
MCS1
23dBm
26dBm
±2dB
MCS2
23dBm
26dBm
±2dB
MCS3
23dBm
26dBm
±2dB
MCS4
23dBm
26dBm
±2dB
MCS5
23dBm
26dBm
±2dB
MCS6
23dBm
26dBm
±2dB
MCS7
22dBm
25dBm
±2dB
MCS8
21dBm
24dBm
±2dB
MCS9
21dBm
24dBm
±2dB
MCS10
18dBm
21dBm
±2dB
MCS11
17dbm
20dbm
±2dB
2.4Ghz 802.11ax HE40
MCS0
23dbm
26dbm
±2dB
MCS1
23dBm
26dBm
±2dB
MCS2
23dBm
26dBm
±2dB
MCS3
23dBm
26dBm
±2dB
MCS4
23dBm
26dBm
±2dB
MCS5
23dBm
26dBm
±2dB
MCS6
23dBm
26dBm
±2dB
MCS7
22dBm
25dBm
±2dB
MCS8
21dBm
24dBm
±2dB
MCS9
21dBm
24dBm
±2dB
MCS10
21dBm
24dBm
±2dB
MCS11
19dbm
22dbm
±2dB
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, We have 90% of the world market,We're a supplier to Facebook.Welcome to contact us!
EMAIL:sales1@wallystech.com
发表于 2022-10-29 23:59 | 显示全部楼层
危难时刻,安慰所托
GMT+8, 2025-7-2 11:20
