查看: 36488|回复: 39
DX短波通联常用英语
发表于 2012-12-26 21:59 | 显示全部楼层 |阅读模式
(1) Good morning (afternoon,evening)! 早上(下午、晚上)好!
  (2) Very good morning to you,my friend! 你好,早安,我的朋友!
  (3) Hello,my friend! 你好,我的朋友
  (4) I’m very glad to meet you. 非常高兴遇见你。
  (5) Thank you for coming back to my call. 谢谢你回答我的呼叫。
  (6) Thanks for your call. 非常感谢你的呼叫。
  (7) Thanks for the nice QSO.(Short QSO,nice contact) 非常感谢这次好的直接联络(短促的联络、好的联络)。
  (8) Thanks for the nice report. 非常感谢你的报告。
  (9) thank you so much for the best enjoyable contact. 非常感谢这次愉快的联络。
  (10) Thank you very much for the information. 谢谢你告诉我这些消息。
  (11) I’m very glad to meet you. 遇到你非常高兴。
  (12) I’m very glad to contact with you. 我非常高兴和你联络。
  (13) I’m so pleasure to see you for the first time. 初次见面非常高兴。
  (14) It’s a great happiness to contact with you again. 和你再次联络是极大的愉快。
  (15) Have a good time. 祝你玩得愉快。
  (16) Have a good holiday(weekend). 祝你假日(周末)愉快。
  (17) Please drive carefully(to work). 请小心些开车。
   (18) Best wish to you and your family! 向你和你的全家致以最良好的祝愿!
  (19) Good DX(Dxing)and seventy-three. 祝你取得远距离通信良好成绩并向你致敬。
  (20) Good luck and good DX.。 祝你走运和取得远距离通信的好成绩。
  (21) Best wish and seventy-three! 致以最良好的祝愿,想你致敬!
  (22) Merry Christmas and happy new year! 圣诞快乐并新年好!
    (23) CQ Europe,this is BY4RSA…BY4RA calling CQ Europe and standing-by. BY4RSA呼叫欧洲台,请回答。
   (24) CQ W1,(I’m)especially looking for Vermont for my WAS,this is BY1PK calling CQ and standing by. BY1PK呼叫前缀为W1的电台,特别是佛蒙特州的电台,因为我希望获得WAS奖,请回答。
   (25) CQ DX,especially looking for zone 2 for my WAZ. 呼叫远距离台特别是2区的台,因为我想获得WAZ奖。
   (26) CQ Ten,CQ Ten,this is BY1TT…calling CQ and standing by. BY1TT在10m波段上呼叫,请回答。
     (27) QRZ? Please call me again,this is … (28) QRZ? Please come in again,this is …
   (29) QRZ? Please give me another call,this is … 谁在呼叫?请再呼叫我,我是……
   (30) JA1 something ,this is BY3AA,I didn’t copy your suffix,please call me again.  JA1,这里是BY3AA,我没有抄上你呼号的后缀,请再呼叫我。
   (31) You have my prefix wrong, It is not BY5,but BZ4,Bravo Zulu Four…  你把我呼号的前缀抄错了,应该是BZ4,不是BY5……
   (32) You have my suffix wrong.It is not RCA,but RSA…你把我呼号的后缀抄错了,不是RCA,是RSA……
   (33) You have a wrong number.It is not Five,butFour.One,Two,Three,Four…,QSL?
    你抄错了数字。应该是4,不是5。是1、2、3、4的4……,抄对了吗?
  (34) What is the last letter in your call sign? 你呼号的最后一个字母是什么?
  (35) My callsign is not BY5RSE.The last letter of my callsign is A like in Alfa,BY5,Romro Sierra Alfa.Do you roger? 我的呼号不是BY5RSE,最后一个字母是A,BY5RSA。明白了吗?
  (36) I’m sorry I didn’t copy your callsign because of QR—Mike (due to QR—Mike),please give me another call slowly.对不起,因为其他电台干扰,我没抄上你的呼号,请慢慢地重复。
   (37) Thanks for coming back to my call,your signal is five and nine,fifty nine…  谢谢回答我的呼叫,你的信号是59……
  (38) You are readability five and strength ten dB over nine hear in Nanjing.  你的信号在南京听起来可辨度为5,强度超过9级10dB。
  (39) Your signal is five and nine plus. 你的信号比59还要好。
  (40) Your signal is five and nine over ten dB.You are coming-in like a local.  你的信号是59加10dB,传过来的好像本地电台。
  (41) You are five and one.Although you are very weak,I read you one—hundred percent,because there is no QR—Mike (interference). 你的信号只有51。虽然你的信号很弱,但我还是能百分之百地听到你,因为这里没有干扰。
  (42) I’m sorry I did’n’t copy my signal report,please repeat it.  对不起,我没有抄上关于我的信号报告,请重复。
  (43) I didn’t get my signal report because of QRM… 因为有其他电台干扰,我没有抄上我的信号报告……
  (43) I wasn’t able to copy my signal report because the band was very noisy。 因为这个波段噪音非常大,所以没有抄上给我的信号报告。
  (44) Your signal is quite weak,QSB. 你的信号相当弱,信号衰落了。
  (45) Is my signal getting weaker? 我的信号变弱了吗?
  (46) I think your signal is going to fade out. 我想你的信号变得衰弱了。
  (47) I think the band is going out. 我想这个波段关闭了(传播不好不能使用了)。
    (48) My name is Li,Lima India,Lima India,Li is my handle. 我姓李,李是我的名字。
  (49) I missed your name,please say again. 我没抄上你的名字,请再说一遍。
  (50) What is your name?I missed it due to QR—Mike,please say again. 你叫什么名字?因为其他电台干扰,我没抄上,请再说一遍。
  (51) My QRA is Li,Lima India,Lima India,Li is my handle,QSL? 我的名字是李,抄上了吗?
    (52) My QTH is BEIJING,November Alfa November Juliet India November Golf…,P.O.Box is 538,538… 我的电台位置在北京,邮政信箱是538号……
  (53) My QTH is OK in the Callbook. 我的地址在《呼号手册》上可以查到。
  (54) Can I have your QSL information? 能告诉我你的交换卡的地址吗?
  (55) Please QSL via the bureau. 请把QSL卡片通过管理局寄给我。
  (56) Please QSL direct. 请把卡片直接寄来。
  (57) QSL via the bureau,OK? 卡片经过管理局寄来,好吗?
  (58) No problem,I will send my QSL card to your bureau.  没问题,我将把卡片寄到你的管理局。
  (59) I will QSL to you 100%(One-hundred percent). 我将百分之百地把卡片寄给你。
  (60) I’d like to have your QSL. 我将很高兴得到你的卡片。
  (61) My QSL manager is W6AL. 我的卡片管理人是W6AL。
  (62) What’s your zip code? 你的邮政编码是什么?
  (63) My transceiver is a FT-ONE Foxtrot Tango one.It is old but very well.  我的收发信机是FT-ONE,虽然旧但很好。
  (64) I’m using a homebrew transmitter which is running 15 watts,the type of my receiver is 239used by military in China.我使用自制的发信机,输出15W,收信机是239型,这是中国制造的军用品。
  (65) I’m using a TS-940 and a linearwhich is about 500 watts output. 我用的是TS-940加一台线性放大器,输出大约500W。
  (66) I am using a three-band five-element beam. 我用的是三波段五单元定向天线。
  (67) My antenna is a five-element Yagi for 15, 20 and 40 meters bands, a three-element Yagi for ten meters band which is homebrew. 我的天线在15m、20m和40m波段是一副五单元八木天线,在10m波段是一副自制的三单元八木天线。
  (68) My antenna is on the roof about thirty meters high from the ground. 我的天线在屋顶上离地面30m高。
  (69) I’m using a two-element quad and it’s ten meters high. 我用两单元框天线,10m高。
  (70) My beam was damaged (breakdown) by a violent typhoon at last week, so I’m using a Inverted-V(Diple,Vertical)antenna and it’s only five meters high. 我的定向天线上星期被一股强台风刮坏了,所以现在用的是一副“倒V”天线(双极水平天线、垂直天线),它只有5m高。
  (71) My antenna is a vertical antenna.Because I have some space limit. In the big eity, we have this type of problems.  我的天线是一副垂直天线。因为我的空间受到限制,在大城市我们有这方面的问题。
  (72) I’m sorry that I’m not QRV on the 16 meters band. 对不起,我还没有准备好在16波段上工作。
    (73) The condition must be very nice today, How much power do you guess I am running?  今天的传播情况一定很好。你猜我现在的输出功率有多少?
  (74) The propogation is badly today, so very strong noise on the band now.  今天电离层情况不好,现在这个波段上有很强的噪音。
  (75) You have a beautiful signal cominghere but I’m using long path to you. 你的信号传到这里非常好,但我是用“长传播”对着你的。
  (76) Please wait a minute(QRX),while I turn my beam to your side. 请稍等,我把天线方向转向你这边.
姓      名:吕炳臣
呼      号:BG1KEQ
会员编号:34024
通信地址:北京市昌平区崔村镇香堂文化新村南五区
邮      编:102212
发表于 2012-12-27 14:55 | 显示全部楼层
发表于 2013-3-18 22:27 | 显示全部楼层
学习了!!
浙江省丽水市遂昌县水阁路83号
钟向炜
一三八八四三六二七一四
BG5GAH
发表于 2014-7-23 18:18 | 显示全部楼层
发表于 2014-8-17 00:16 | 显示全部楼层
哦,很好的资讯。学习了。
发表于 2014-10-6 09:54 | 显示全部楼层
发表于 2015-1-2 08:33 | 显示全部楼层
太好了,遗憾的是我不会英语。
发表于 2015-1-5 13:39 | 显示全部楼层
真心不会说啊
发表于 2015-6-5 12:26 | 显示全部楼层
很实用
呼号:BH3MDE
★★★★淘宝店铺:bh3mde.taobao.com
地址:石家庄市清真寺街118号无线电对讲机等设备专卖
QQ:805012242
发表于 2015-7-13 19:04 | 显示全部楼层
BH9BTM
GMT+8, 2025-7-4 12:28
