查看: 3041|回复: 0
紧急求购!N4433A网络分析仪校准件
发表于 2016-6-1 17:38 | 显示全部楼层 |阅读模式
紧急求购!N4433A网络分析仪校准件
如贵公司工厂办公设备,电子仪器仪表设备需要处理掉,我们可以上门收购!
如果贵工厂倒闭,所有设备要处理,我们即刻安排上门洽谈收购!
无论贵公司电子仪器设备,办公设备有多少,数量不限,我们通通全部要!
东莞瑞科电子仪器回收公司
李R 手机:18925768594
电话:0769-81285527
QQ客服:1960333287
地址:东莞市塘厦镇花园街
Agilent | N4433A|四端口电子校准件|网络分析仪校准件|20GHz|3.5mm
品牌: 安捷伦 | Agilent | 惠普 | HP
主要技术指标
  * 300 kHz to 20 GHz frequency range
  * Standard 3.5 mm (f) connectors
  * Fast full 3- or 4-port calibration with a single connection
  * NIST traceable accurate calibrations
  * Reduced connector wear
  * USB interface for direct control with PNA and ENA series of network analyzers
  * Reliable solid-state switching
  * Mixed 3.5 mm male/female connectors option available
主要描述
The agilent N4433A Microwave electronic calibration (ECal) module makes calibration of vector network analyzers fast, easy, and accurate. ECal is a precision, single-connection calibration technique for your vector network analyzer. Performing a full three- or four-port calibration takes less than half the time and number of connections using ECal versus mechanical cal kits. Furthermore, the accuracy of the calibration is comparable to mechanical methods. Traditional mechanical calibrations require intensive operator interaction, which is prone to errors. With ECal, the operator simply connects the ECal module to the network analyzer and the software controls the rest.
ECal modules are transfer standards capable of transferring the factory calibration accuracy to your network analyzer. The agilent PNA and ENA series of network analyzers controls the N4433A module directly through a USB interface. PNA Series network analyzers require firmware revision 2.5 or higher.
回收各种二手电子仪器:现金支付、上门收购。我们的收购足迹到过马来西亚,非律宾,台湾,香港澳门,北京、安徽、上海、广州、杭州、天津、太原、湛江、福州、苏州、东莞等地。
无论你在国内还是国外,一个电话,我们都可以达到彼此双赢的目的。
GMT+8, 2025-6-26 00:40
