查看: 7442|回复: 3
自制多用写频线
发表于 2014-9-13 23:31 | 显示全部楼层 |阅读模式
自制多用写频线
看到很多人都在做写频线,感觉DIY好玩,自己也就做个玩玩.首先说明我自己有写频线,
如图1file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps9723.tmp.png
因为我反正材料配件多,工具也齐,有事没空DIY玩玩吧,,不管怎么样,开心就好.如下图
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps9734.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps9754.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps9764.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps9775.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps97A5.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps97B5.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps97C6.tmp.png
于是开始搜索对讲机写频线定义及广大网友的经验,在这里感谢高手们的奉献!!
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps97C7.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps97D8.tmp.png
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps97E8.tmp.png
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps97F9.tmp.png
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps9809.tmp.png
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps981A.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps982B.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps983B.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps984C.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps985C.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps986D.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps986E.tmp.png
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps987F.tmp.png
资料有了,材料有了,工具有了,开工啦.....
反正耳机多先废一个吧,,6根线全接上再说,
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps988F.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps98A0.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps98C0.tmp.png
再按网友们说的定义接上PL2303
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps98D1.tmp.png
file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps98E1.tmp.png
问题来了,我用原写频线能写,DIY的怎么也不能,按网友们说的,RX:数据接受,TX:数据发送,  还是不行,没办法哦,我的PL2303多嘛,又换2303还是不行再换2303还是不行,万用表检测耳机线有没接牢,100%没问题.网友都说只能接---RX , TX,  GND ,三线,千万不能接电源+5V,到底能不能接?
但怎么就是不能读写呢?那问题在哪里??
我的软件是这两种file:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps98E2.tmp.pngfile:///C:/Users/ADMINI~1/AppData/Local/Temp/ksohtml/wps98F3.tmp.png
期待有高手出现指导,挽救我DIY的死心,,
原配线可读写,
怎么按广大网友的说法,DIY就不行呢?
网友们啊,你们不会都是忽悠的吧??
发表于 2014-9-14 22:17 | 显示全部楼层
没图了
电话 15324253153
地址 河北省唐山市路北区轻工学院
发表于 2014-9-15 17:14 | 显示全部楼层
图呢?呵呵
发表于 2015-1-28 13:25 | 显示全部楼层
谢谢楼主分享,楼主威武,呵呵
GMT+8, 2025-6-18 15:59
