查看: 2829|回复: 1
wallys/802.11ax wifi 6E QCN9074 IPQ8072 4X4 2.4G & 5G
21
发表于 2022-10-28 11:39 | 只看该作者 回帖奖励 |倒序浏览 |阅读模式
https://www.youtube.com/watch?v=-WxNI6WXFDI&t=22s
Features
■ Qualcomm Atheros IPQ8072A AR Quad Core CPU
■ On-board 5GHz radio, up to 2475 Mbps physical data rate,On-board 2.4GHz radio, up to 1147Mbps physical data rate
■ 8 MB NOR Flash, 256MB NAND FlashNAND Flash can be up to 1GB as optional
■ Support 11ax TX Beamforming,Support 11ac/ax MU-MIMO DL and UL,Support OFDMA DL and UL
■ Supports Dynamic Frequency Selection (DFS)
■ DDR 1GB DDR3L(Support DDR3L can be up to 2GB as optional)
■ M.2 connector can support QCN9074 production
Absolute Maximum Rating
Parameter
Rating
Unit
Operating Temperature Range
-20 to +70
ºC
Storage Temperature Range
-40 to +90
ºC
Operating Humidity Range
5 to +95 (non-condensing)
Storage Humidity Range
0 to +90 (non-condensing)
Hardware Specifications
Symbol
Parameter
CPU
Qualcomm Atheros Quad Core ARM Cortex 64-bit A53 Processor IPQ8072A 2.2GHz CPU
CPU Frequency
Derived from Qualcomm Atheros AP.HK09
System Memory
1x 512MB, DDR4 2400MHz 16-bit interface(RAM can be up to 2GB as optional)
Frequency Range
2.412~2.472GHz,
5.150~5.825GHz
M.2 Slot
1x M.2 Slot with PCIe 3.0
Modulation Techniques
OFDMA: BPSK, QPSK, 16-QAM, 64-QAM, 256-QAM, 1024-QAM
Environmental Temperature
Operating: -20ºC to 70ºC,
Storage: -40ºC to 90ºC
Flash
NOR Flash: 8 MB
NAND Flash: 256MB(1GB optional)
Wireless
On-board 4x4 2.4GHz MU-MIMO OFDMA 802.11b/802.11g/802.11n/802.11ax, max 17dBm per chain
On-board 4x4 5GHz MU-MIMO OFDMA 802.11a/802.11n/80.211ac/802.11ax, max 17dBm per chain
8x U.FL Connectors
Reset Buttons
1x S/W Reset Button
DC Jack Input
1x DC Jack Connector: 12V
Interface
4x 1Gbps Ethernet Port,
1x 10Gbps Ethernet Port
1x 10Gbps SFP
2x USB 3.0 Port
1x JTAG 20 Pin Connector
1x Serial Port 4 Pin Connector
LED
2x RGB LED Indicators
Power Consumption
TBD
Wallys Communications (Suzhou) Co LTD develops, designs and manufactures wireless communication products, including routers, network cards, AP and antennas. Customization is also supported, We have 90% of the world market,We're a supplier to Facebook.Welcome to contact us!
EMAIL:sales1@wallystech.com
https://www.wallystech.com/
Wallys Communications (SuZhou) Co.Ltd
5371
发表于 2022-10-29 21:29 | 只看该作者
危难时刻,安慰所托
